Troubleshooting - Engine has poor performance and poor acceleration
Article #542291
- Improper, old, or contaminated fuel
- Replace fuel. Top Fuel is recommended.
- Glow plug fouled or weak
- Check for solid green light on EZ-Start® control box gow plug status LED. Test and/or replace glow plug.
- Readjust carburetor to factory break-in settings
- Dirty air filter
- Clean and relube or replace air filter
- Slipper clutch loose
- Tighten the slipper clutch
- Engine clutch slipping
- Replace clutch shoes
- Excessive load on the engine
- Check for bound drivetrain
- 2-speed shift point needs adjusting (2-speed vehicles only)
- Tighten the shift point adjustment screw clockwise to raise the shift point (shift later) or counterclockwise to lower the shift point (shift sooner).
- Stripped or worn spur gears
- Replace the spur gear(s) before continuing to run the model.
- Carburetor low speed mixture set too rich
- Adjust the TRX 2.5/3.3 or Pro .15 Low speed needle setting. See also carburetor care for more information.
- Engine excessively worn
- Repair or replace engine through the Traxxas Engine Replacement Plan.
