Throttle and Brake Linkage Adjustment
The
following steps outline how to reset the throttle/brake servo to the
factory setting and how to adjust the linkage. |
Jato® Linkage |
Nitro 4-Tec 3.3 Linkage |
Nitro 4-Tec (with TRX® Pro.15)
Linkage |
Nitro Rustler 2.5
Linkage |
Nitro Rustler® (with Pro.15 Engine)
Linkage |
Nitro Sport Linkage |
Nitro Stampede® Linkage |
T-Maxx Linkage T-Maxx 2.5 Shift
Linkage T-Maxx 2.5R Shift
Linkage |
Revo® (and Slayer) Linkage, Idle Gap = 0.5mm-1.0mm |
![]() Revo® Slight Brake Gap ![]() ![]() Revo® Steering Linkage |
6) Many hobbyists make the mistake of adjusting the throttle trim on the transmitter to raise the idle speed instead of adjusting the idle speed screw on the carburetor. This accomplishes two negative effects: first, the engine may stall every time the brakes are applied. Second the brakes may not engage at all, which can lead to other problems. |
