Model feels sluggish (poor acceleration) (Nitro)
Article #542399
- Engine poorly tuned or is new and requires break-in
- Follow the manual's instructions for break in (go here for Pro .15 factory break-in settings), and then for tuning the engine.
- Onboard battery pack is not properly charged
- Charge battery completely, or replace onboard AA batteries (nitro models).
- Clutch shoes worn out
- Replace the worn clutch shoes and clutch spring with a fresh set.
- Slipper clutch is set too loose
- Tighten the slipper clutch
- Over geared
- You must gear appropriately for your environment. Use a smaller clutch bell (fewer teeth). Calculate Gearing.
- Missing axle drive pins
- Install drive pins in the axle
- Tires slip on the rims
- Glue tires to the wheels.
- Stripped spur gear
- Replace damaged spur gear (see article here, T-Maxx example illustrated).
- Stripped transmission gears
- Replaced damaged gears
- Damaged Drive Belt (4-Tec)
- Inspect the drivebelts for loose tension or missing teeth and adjust or replace as necessary.
