How To - Install u-joints
Article #542481
How to install u-joints
This
procedure is used to install the metal u-joints
into the plastic output yokes on all Traxxas models.
Step 1 -
Insert one of the pins of the u-joint into one of the yoke holes as far as
it will go.
Step 2 - Slide the slotted end of the
u-joint installation tool between the u-joint ball and the other side of
the yoke (the u-joint pin should fit into the slot of the u-joint
tool).
Step 3 - Press the pin inward until it
pops into the hole of the yoke.
Assembled
u-joint
