Project Build: TRX-4 2021 Ford Bronco Part 2
Adding Lights, Custom Graphics, and a Winch to our Project Build
In Part 1 of our 2021 TRX-4® Bronco build we elevated the durability and performance of the stock truck to the next level with a host of aluminum and chromoly steel accessories. In the second installment of our project build, we're adding some top-notch accessories like Traxxas' Pro Scale® LED lighting system and winch, along with some custom graphics and wheels. Let's get started!
Wheel and Tire Options
The Bronco’s standard-issue Canyon Trail tires are some of the best off-road adventure treads you can get stock or aftermarket, but we’ve got a clever mix-and-match planned. We're adding the 2.2″ tires from the TRX-6® to give the Bronco a wide-track, big-wheel look that’s extra special. With no-glue Method 105 replica beadlocks, we can even install 2.2″ Canyon Trail tires later without springing for another set of wheels.
Pro Scale Accessories
The 2021 Bronco is extra-realistic right out of the box with its factory-Ford colors and injection-molded details. To take authentic off-roading to the next level, we’ll add the innovative Pro Scale LED Light Set and Pro Scale Winch to the package. These accessories are engineered for easy installation and reliable operation, with the durability and all-weather versatility you demand for trail-trucking adventure.
Pro Scale Winch
The Pro Scale Winch includes a fairlead, key-style remote fob, metal hook, fabric hook strap, and line retainer. Over four feet of high-strength red line is on the spool, and blue and black line are available separately. You can also trick out your winch with anodized-aluminum fairleads in five colors.
Extra Custom Touches
The Bronco build gave us a chance to try a few customizing tricks we dreamed up, and we think they turned out pretty well—but you tell us! We gave the Bronco a new rear-view look with fuel canisters and a jack borrowed from the Land Rover® Defender®, and custom graphics cut out of adhesive vinyl. If you like the look, there’s a full-size template you can use to make your own. Give it a try, or make your own design. We’d love to see what you come up with.
Tricked-Out Traxx
The Deep Terrain Traxx are the ultimate TRX-4 accessory for sand, snow, mud, and other soft surfaces that wheeled rigs struggle with. The wide, aggressive tracks just float over terrain that swallows up traditional tires. And the Traxx look wild, which is always fun. We’re going to go just a little bit wilder.
What do you think?
Be sure and let us know what you think of our Bronco build-up. Show us what you’re working on! Post and tag your pics on your favorite channels with #MyTRX4Build, and be sure to follow Traxxas on Facebook, Instagram or Twitter—you just might see your machine featured for all your fellow Traxxas fans to enjoy.
