Drag Slash Tuning Pt 3: Differential Setup
Part 3: Tuning the Sealed Differential
The Drag Slash’s new Pro Series Magnum 272R transmission features a sealed, silicone-filled differential for long-lasting performance and enhanced tuning capability. The factory differential setup is the result of extensive testing and will be ideal for the majority of competition scenarios, but altering the diff’s action via fluid viscosity may help you achieve an even more refined setup for your track or the type of driving you prefer to enjoy with your Drag Slash. In Part 3 of our tuning guide, we’ll cover removing and refilling the differential, and what to consider when selecting your diff fluid.
From the factory, the Drag Slash’s differential is filled with very thick 500K differential fluid to optimize performance for drag racing. You may wish to experiment with lower-viscosity fluid for bumpy tracks, or for better road handling if you’re enjoying your Drag Slash as an all-around street car. The Pro Series transmission is designed for easy differential access with no need to split the gearbox halves, so experimenting with diff fluid viscosity doesn’t require a lengthy bench session. Just follow these steps:
Differential Oil
The Drag Slash’s stock silicone diff fluid is 500K weight (5039). The 5136X diff oil set includes 10K, 30K, and 50K weight fluid, and 5130X 100K fluid is available separately. The lower viscosity numbers mean these fluids are less viscous (“thinner”) than the Drag Slash’s stock 500K fluid, and will allow freer diff action. For even heavier diff action than stock, the diff can be filled with the putty-like 1-million weight fluid used by the Unlimited Desert Racer. If you’re racing on an ultra-high-traction track, the super-thick stuff might be worth a try.
Put Everything Back Together
Once you've topped off your differential with new fluid, it's time to put everything back together. Reverse steps 1 – 6 to reinstall the differential and attach the rear suspension module to the chassis, then hit the street or strip with your new setup.
That concludes our Drag Slash Tuning Guide. We hope your new insights will help you go faster and have more fun, whether you’re out to win races on the strip or just blasting around the neighborhood. Tell (and show!) us what kind of Drag Slash action you’re into by tagging Traxxas on Facebook, Instagram, Twitter, and YouTube. We’ll be watching for you!
If you missed any steps along the way, be sure to check out Part 1 here, or Part 2 here.
