How to Align Servos on Dual Servo RC Trucks
Learn the proper procedure to adjust a dual-servo setup
It’s a familiar story: mailboxes jump out of nowhere and curbs appear overnight to catch RC drivers unaware. If you’ve ever experienced these or other road hazards you know that a strong hit could damage your steering servo. Replacing a single servo is a pretty straightforward job, but what about RC trucks with dual servos? This article discusses the importance of proper alignment when working on dual-servo RC vehicles and how to adjust them.
This article assumes you are replacing at least one servo, but it’s always a good idea to check your servo alignment from time to time. If your servos make a constant buzzing sound or get warm without any steering input, that’s a good sign you need to check their alignment. Here’s what to do.
Required Tools |
Getting Started
With everything tightened down, turn on the vehicle again and test your steering. With no input on the steering wheel, the servos should be quiet. If you hear a buzzing sound from the servos, they are not in perfect alignment. Try to realign them again until the buzzing stops. Failure to properly align the servos will cause undue stress and may even lead to servo overheating and damage. Once everything is aligned properly, it’s time to hit streets and have some fun. Just watch out for those RC-hating mailboxes!
